using CrushStation
Home Forums Products Stompboxes using CrushStation
Viewing 6 reply threads
    • #112696
      lironas2006
       hey friends how are you? i just dawnloaded the crushstation and need help how to conect it the my amp- i am using 2 h9 and mesa boogie roadking.
      do i need to follow the the pre/post mamual and do as it say?
      thank you
    • #139790
      Probably not. Pre/Post is really for advanced users – you would know if you needed it.
      • #139791
        Given To Fly
        The Road King is for advanced users too.
        The simplest setup would be guitar – H9 – Road King. However, if you are using the H9’s in one or both of the Road King’s FX Loops the best setup might not be simple anymore. How do you normally use your H9’s? I have no doubt this can be figured out quickly but its a situation that will require some figuring out.
    • #139794
      lironas2006
      so anyone can tell me what is the right way to connect the h9 when i use it with dist?
      with any dist its came before the amp- what i should do in that situation?
      thank you
    • #139796
      rlynch
      thank you
      I think pre/post is best if your using a foot controller of some sorts. Watch the video Eventide has online for simple pre/post operation.smiley
    • #139797
      rlynch
      thank you
    • #139815
      lironas2006
      thank you
    • #139848
      rlynch
      you can check out my post on G2-dual h9’s- stereo-dual amps-dual fx loops. I think if you have invested in h9’s your next step should be a quality footcontroller. You can run one in your loop if its instrument level if its not have one installed like the metro amp loop, thats what I did.then you have lots of options
      1. run 1 h9 in stereo ( as long as footcontroller has a stereo 4 in/out loop)
      2,run the other h9 pre/post into your footcontroller. I place pich/octave in loop 1 fuzz in loop 2 and h9 pre in loop 3 . then you can place h9 in last loop for post.
      3. use 910/949 EVH preset in stereo then your analog distortion then the other h9 thats in pre post can bring in some phaser or flanger.
      tons of options
      now you can run fuzz with pre h9 phaser for example or your analog distortion pedal with h9 stereo reverb or delay.
      of course stereo really needs 2 amps…its only $  but once you go stereo you will not want to use mono anymore 🙂
