Using expression pedal for Wah and Whammy
Home Forums Products Stompboxes Using expression pedal for Wah and Whammy
    • #115872
      Shaked97
        Hey everyone,
        I have a H9 on my board and I want to start using expression pedal instead my crybaby (and to add a Whammy pedal)
        Someone uses expression pedal for wahwah and whammy and can tell if it’ll do the job or should I stay with my crybaby.
        Thanks.
      • #154615
        bohan
          Shaked97 wrote:
          Hey everyone, I have a H9 on my board and I want to start using expression pedal instead my crybaby (and to add a Whammy pedal) Someone uses expression pedal for wahwah and whammy and can tell if it'll do the job or should I stay with my crybaby. Thanks.
          Do you have an expression pedal now? You can try the Q-wah (for example, preset F6 in H9 Control) for a wahwah effect, and PitchFlex algorithm for all sorts of whammy effects.
        • #154632
          camn
            They are usable depending on your expectations.
            I played with an EXP only in a band that was not ~terribly~ solo-heavy. So I needed a wah for funky rhythm parts and the like, and it was totally fine. The whamme doesnt track as well as Digi’s, but it was usable if it isnt the total focus of your lines.
            NOW, I play more solo-heavy stuff, and I have an Xotic Wah on my board. I don’t use the Whammy enough to want one though. When I need it, the H9 suffices.
            You should, however, get a EXP for the H9 for OTHER reasons. It’s use on fading in delays, sweeping effext mixes, etc is totally worth a spot- I think moreso than a DigiWhammy on anyone’s board except Tom Morellos 🙂 Then you can test out the Algos for yourself, see what you wanna do.
          • #154617
            Shaked97
              bohan wrote:
              Shaked97 wrote:
              Hey everyone, I have a H9 on my board and I want to start using expression pedal instead my crybaby (and to add a Whammy pedal) Someone uses expression pedal for wahwah and whammy and can tell if it’ll do the job or should I stay with my crybaby. Thanks.
              I don’t have expression pedal yet. I know that the effect are exist. my question it’s about their quality and their dynamices compared the Crybaby and the Whammy.
