Home › Forums › Products › Stompboxes › using foot controller with h90
- This topic has 10 replies, 3 voices, and was last updated 2 years, 2 months ago by
Eventide Staff.
February 12, 2023 at 8:35 am #169058
hi, I am using a ehx triple foot controller
on one preset I have created 3 different hotswitch sounds for different parts of the song but whenever I press any of the buttons on it nothing changes, I have tried both ports in the back of the h90
is there something I am doing wrong here?
February 12, 2023 at 9:05 am #169060
Have you calibrated the H90 for your aux switches yet? [System] – I/O – Exp & Aux – Calibration On (then Calibration back to Off once all are locked in).
February 13, 2023 at 11:40 am #169078
I can’t seem to find an option for calibration in there? just some assignments for midi
February 13, 2023 at 11:46 am #169079
You might be on the wrong page in the System menu:
https://cdn.eventideaudio.com/manuals/h90/1.3.0/content/system-menu/index.html
https://cdn.eventideaudio.com/manuals/h90/1.3.0/content/system-menu/io.html
February 13, 2023 at 11:51 am #169080
ah so that menu is only availible on the actual unit and not through the software?
February 13, 2023 at 12:18 pm #169082
That’s correct, you must calibrate the expression pedals or switches on the pedal itself.
Press and hold the Programs and Routing buttons to enter the System Menu, scroll over to “I/O” and select it, and then scroll over to the “Exp & Aux” page to calibrate them.
February 13, 2023 at 12:06 pm #169081
It’s not in front of me right now, so I don’t recall. But if that is the case, it would make sense to me. You are calibrating accessories to the hardware itself. Offhand, I can think of another example: Under System / About, the Versions are a lot more detailed & specific.
February 14, 2023 at 2:46 pm #169105
after calibrated it still doesn’t work properly,
one of the foot switches is turning the effect on or off (green light to no green light) despite all hotswitches being assigned to different eq variations of the same effect (as per my screenshot)
February 14, 2023 at 3:44 pm #169106
In your screenshot, you have Aux Switch #2 assigned to Program > Byp/Act, so that would make Footswitch #2 bypass or activate the Program. You will need to delete this mapping by setting the Control Source to “Off”.
In the Performance Parameter Mapping page, try the following:
Switch: P
Parameter: HotSwitch 1
Control Source: Aux > Switch #1
This will map HotSwitch 1 to Aux Switch #1.
If you’d always like your Aux Switches to control the 3 HotSwitches, this can be done using Global Mappings. These mappings are configured under System > External Control.
https://cdn.eventideaudio.com/manuals/h90/1.3.0/content/appendix/global.html
February 21, 2023 at 5:42 pm #169318
thank you,
is there a way to set them so I press them once to activate the hotswitch and press them again to turn it off and return to normal settings?
also is it possible to add or remote an effect with it ?
February 22, 2023 at 10:03 am #169343
Yes, mapping a HotSwitch to an external footswitch will make it so the footswitch activates the HotSwitch. Pressing the footswitch again will deactivate the HotSwitch.
Any parameter can be mapped to a controller. Press and hold the parameter to enter the mapping menu, and assign the control source to whatever you’d like to use. You can also use the “Learn” function – https://cdn.eventideaudio.com/manuals/h90/1.3.0/content/edit-modes/parameters.html#mapping
