Home › Forums › Products › Stompboxes › Using H9 with 2 iputs and one output
September 5, 2014 at 9:00 pm #111901
I want to use an H9 with both inputs, where input 2 will only receive signal when the tuner is on (using a programmable switcher) but with one output in mono.
Will there be any effect on the sound considering I have something connected to input 2 but with no actual guitar signal when playing ?
September 5, 2014 at 9:07 pm #126643
I think there will be. The H9 will detect that something is plugged into the second jack and configure its algorithms to run in stereo mode but there won't be a stereo signal…
September 5, 2014 at 9:21 pm #126644
Will there be any effect when using algorithms which don't work in true stereo ? i.e. sending the exact same signal to both outputs ?
September 5, 2014 at 9:29 pm #137312
I don't think so. Hopefully, my colleague, Nick, will chime in to verify that. By the way I posted a classification of the algorithms by whether they're dual mono, stereo summed to mono, or true stereo on the gearpage a while back:
http://www.thegearpage.net/board/showthread.php?p=17955988#post17955988
September 5, 2014 at 10:12 pm #137314
If you send the same thing to both inputs, you should be OK.
When you only plug in one jack, it connects the signal to both channels, so it should be the same thing.
September 6, 2014 at 11:04 am #137316
The inputs are not getting the same signal. Input 2 is for tuner only, so basically, it's like having just a plug in there
