Using hotswitch in Preset Mode / Space Pedal
Home › Forums › Products › Stompboxes › Using hotswitch in Preset Mode / Space Pedal
Viewing 3 reply threads
    • #186064
      barrycreed
        Before I look to get a Space, saving presets would be important to me and being able to scroll up and down using my feet, however the hotswitch would also be an important incentive for me.
        Can I use the hotswitch in preset mode, or would I have to use an external aux switch? e.g. middle button and right button are used to scroll up and down the presets, and the external button used as the hotswitch button. Is this possible?
      • #186067
          In Presets mode, the 3 on board footswitches will always be for up/down scrolling with the middles and right switch, and loading or active/bypass using the left footswitch.
          You can use an aux switch to perform the HotSwitch in Presets mode.
        • #186068
          barrycreed
            Thanks for the reply. So a 3 button aux switch, e.g. the GFI triple system, could be used with 1 button controlling the hotswitch, and the other 2 controlling something else. A 1 button switch should be fine if all I wanted to control was the hotswitch?
          • #186069
              That is correct. I would suggest the Barn3 OXU aux pedals that we offer: https://store.eventideaudio.com/collections/accessories/products/oxu-three-universal-aux-switch
