Using midi, expression pedal, and auxiliary pedal simultaneously
Home Forums Products Stompboxes Using midi, expression pedal, and auxiliary pedal simultaneously
Viewing 3 reply threads
    • #107045
      ctc
      If I have the timefactor connected to and controlled by an RJM Mastermind foot controller using a midi cable, can I simultaneously use an expression pedal and an auxiliary pedal connected directly to the timefactor to modify it on the fly?
    • #120330
      You can. If you get too busy there is a risk of confusing yourself, and the response may slow down slightly.
    • #120331
      ctc
      So in this setup your recommendation is to plug the expression pedal directly into the midi controller?
    • #131579
      Really depends on what you are trying to do.
      But, you will probably get more responsive control by plugging the expression pedal directly into the 'Factor. Some trial and error may be needed.
