Home › Forums › Products › Stompboxes › Using multiple guitars with my H9
November 9, 2015 at 3:49 pm #113014
Hey all, I’ve serached the forum and didn’t find an answers so I thought I would post this here, thanks for the help in advance!
Problem: So I love my H9 so much that I use it with my acoustic rig now, the problem is that my acoustic output is active and my electric output is passive, when I adjust the H9 for 1 guitar it messes up the other. (ex when I set the output all the way up for my acoustic, if I switch to my electric I get the red clipping light all the time) Is there a way that I can save setting parameters for different guitars? Or is there another work around that I am unaware of?
Thanks,
Loren
November 9, 2015 at 3:52 pm #141479
Hi Loren,
You'll have to create other versions for your acoustic guitar otherwise you'll have to edit the preset inputs on the fly. You could consider creating a new preset list strictly for your acoustic guitar or perhaps putting your guitar effects in the first five slots and your acoustic ones in the next five slots, for example. Hope this helps.
November 10, 2015 at 4:01 am #141495
So I can save different presets with different input levels? It is not a global setting? To be clear I am talking about the “input gain and level meter” on the H9 control.
Using your example above, copy the same preset but with a different output for your electric. Input gain is global. You can't set it differently for each preset.
