Utility/Bank Menu Troubleshoot
Home › Forums › Products › Stompboxes › Utility/Bank Menu Troubleshoot
    • #107829
      svelard
        Hi… I bought my timefactor around february 2011… as soon as I got ir i made the update.. just a few moments ago, y was fooling around with the system menu… i entered to utility / banks… and when i turned the encoder knob the screen showed: L1 – H49… and I can't get it back to H50… what can i do?
      • #121999
        This is was known bug in V3beta1. I just checked TF V3beta16 and I can once again get to bank 50. You might try turning the pedal off then back on, then re-try setting the banks again. Also, if you didn't upgrade to the latest beta (V3b16 at the moment), you may want to try that. If either of those doesn't work, try doing a reset to factory settings (UM p41).
        There have been a few threads about this issue. This link is to one of them.
        http://forum.eventide.com/cs/forums/p/6909/31321.aspx
      • #122017
        svelard
          problem solved!! thanks =)
