V4.01 & Preamp algos
Home Forums Products Rackmount V4.01 & Preamp algos
Viewing 3 reply threads
    • #106588
      scottburk
      First of all, thanks for getting the remote modulation crash issue fixed so quickly.
      Second, I would like to disable the volume pedal function on the guitar preamp presets but I can't seem to find exactly where in the algo the pedal is controlling the output level so I can turn it off.  Any suggestions?
    • #119371
      IDeangelis
      The Distortion Preamp algorithm has a MANUAL_PED parameter that controls volume. It's patched to EXT_1 which by default is patched to Pedal . Just Edit the preset and in the second parameters menupage you'll find it. Press and hold its soft key and set Source to OFF.
      I
    • #119378
      scottburk
      I don't know how I missed that.  Thanks Italo.
    • #130495
      IDeangelis
      Fridays!!!!
      Wink
      I
