December 24, 2012 at 10:31 pm #1094192oldmanMember
I want to combine vibrato with distortion preamp together in the same effect.
Is that possible? Can I either add fuzz to vibrato or vice versa? I sure have done my best to read the manual and try to figure this out.
hank you.
December 28, 2012 at 8:40 pm #1241342oldmanMember
Nobody?
December 28, 2012 at 8:56 pm #124135
You should look through the Presets Manual. To run two effects at the same time they both need to be labeled "xfade."
There are a number of "xfade" distortion effects and a number of "xfade" vibrato effects, so if you used one of each, you should be moving in the right direction. But, you will want to tune them by ear for the right sound.
December 28, 2012 at 9:14 pm #1241362oldmanMember
thanks. time's a factor right now.. nobody at Eventide could work that up and I could upload it to the Eclipse? 🙂
December 28, 2012 at 11:28 pm #135103
Sorry – some things you have to do yourself. Apart from the obvious, there are a lot of possibilities here, and only you will know what you want the sound to be. You can run through a few options in 5 minutes.
December 29, 2012 at 12:23 am #1351052oldmanMember
The obvious to me was diggout out my old fuzz box, but I'm trying to avoid that.
Thanks..
December 31, 2012 at 4:32 pm #135109wilkinsiParticipant
"In the same effect" – you mean 2 algorithms in one program? Simple. Don't xfade, because it will only allow FXA to work. Choose series, parellel or one of the mono routings. Then "steal" the needed algorithms from programs containing them, and load them into FXA and FXB. Then adjust parameters to taste.
December 31, 2012 at 5:22 pm #1351112oldmanMember
Thanks. Would the Tutorial on page 19 "creating a program from scratch" be what you're saying? then I have to hope I can save it as 'my' effect.
December 31, 2012 at 10:30 pm #135112wilkinsiParticipant
… then you just press PROGRAM twice and there it is on Hot Key 4.
January 1, 2013 at 12:26 am #1351132oldmanMember
Ok.. but it has to be MIDI selectable.
