View two H9’s in H9 Control
Home › Forums › Products › Stompboxes › View two H9’s in H9 Control
    • #113632
      kevin may
        We have an H9 Max and H9 Core. We just updated the core to version 5.4, same as Max. When we restarted H9 Control, we only see the MAX. Looking around now to see if there are port conflicts. I should be able to control both from one H9 Control app, right?
        Thanks for any and all FEEDBACK!!!
      • #144097
        gkellum
          Yes, you should be able to control both from H9 Control.  After updating, sometimes weird problems can occur;  resetting the H9s system settings oftentimes helps.  You can do this by turning your H9 off and then turning it on again with the right footswitch and the HotKnob switch pressed (the one in the upper left hand corner of the H9).
