VoodooLab Ground Control and TF RCV CTL Problem
Home Forums Products Stompboxes VoodooLab Ground Control and TF RCV CTL Problem
    • #106608
      moonages
      Maybe an easy problem but I don´t get it solved.
      The VoodooLab GC allows you to switch the TF ON or OFF via midi CC messages.
      I can switch the TF ON and OFF with no problem, but the status led on the associated switch on the Ground Control is lid when the TF is turned OFF and vice versa. Not useful.
      Anybody an idea how to change it the other way round?
      I´ve already tried all possible settings on the Ground Control.
      thanks in advance
    • #119406
      Assuming by ON and OFF you mean BYPASS..
      The latest TF/MF/PF software has a CC option called ACT (ACTive) which is the opposite of BYPASS – this may be what you need.
    • #119410
      moonages
      nickrose you are right. With the latest software, the problem is solved. Thanks for your quick respond and help.
