VSIG
Home Forums Products Rackmount VSIG
Viewing 4 reply threads
    • #106887
      Is the VSIG editor working on Windows 7 64 bit?
      Also, since my new DAW PC does not have a serial port, will using a USB to serial cable work on teh H7600?
    • #120033
      chadkettering:
      We haven't tested it yet, but can't think of any reason why it shouldn't. You may need to run it in Administrator mode.
      chadkettering:
      Again, no reason why it shouldn't – the H7600 is expecting RS232 – doesn't care where it comes from. There is a remote possibility that Vsig will not recognize the cable – the solution would be to try a different one.
      To conclude – both of these should work – if they don't, we'll have to fix them.
    • #120080
      philjochum
      Chad,
      I'm running Vsig 2 on Windows 7 (er, 6.1 <wink>) x64 without problems. I set it to run at XP SP3.
      I'm using a USB-RS232 adapter with the Prolific 2303 chip in it.  Once I found a recent driver package (from SerialGear.com, IIRC), it came right up.  Whatever adapter you end up with, just make sure to set the comm spec in Device Manager as well as in Vsig.
      ~Phil
    • #120084
      Great,
      I am running VSIG now in Win 7 using my Midi interface with no problems.
    • #131277
      ThreeFingersOfLove
      I am running VSig in Windows 7 as well, using a serial cable and it works fine.
