Home › Forums › Products › Vsig and Preset Development › Vsig Connection to DSP4000 Via COM port question?
March 4, 2012 at 8:46 am #108491
Hello EVENTIDE and beloved users
i have a question to ask!
i want to use "Vsig" or vSigX Pc or Mac with my DSP4000 unit.
in the back of the DSP4000 there are the COM ports "IN" OUT" do i need to connect them both?
To use the "Vsig" or vSigX" ?
in my Mac or Pc i do not have a COM port any more will these do the job…..
"USB 2.0 TO 9PIN RS232 COM PORT SERIAL CONVERT ADAPTER" or i need different Adapter?
!! If the COM ports need to be connected both "IN" "OUT" so it means i need 2 Adapters? !!
in the DSP4000 unit i see that the "IN" "OUT" COM ports are both "male" type connections and the all the Adapters in Ebay are also male type connections will a cable with female on both the ends do the job? (i sure it will but i got to make sure 🙂
Sorry if i not most clear with my question 🙂
Big thanks
Sagi.s
March 5, 2012 at 4:52 pm #123189
Only a few of the more recent members of the DSP4000 family have PC-type serial ports – these will only have a single connector. It sounds as though yours is an older one, which has a PA-422 interface. This is not suitable for computer use.
But, you can always use MIDI if you have a suitable computer interface.
March 5, 2012 at 5:29 pm #123196
Hi nickrose thanks for your answer
Yes i have the PA-422!
if i can use midi is great,i have more experience with midi devices,i must ask because my pc is not in a ready use!! " Vsig" can communicate with the DSP4000 via midi?
From your answer i understand it is,i will read the manual for more info.
One more thing about the "vSigX" (mac) can it also be used with midi?
in the "vSigX" preferences i see the midi option but it appear that i can't enable it! any info about that will be great,i will also read the manual for more info!
i must ask for these guide lines it help me to get in to proportion.
Again big thanks….
Sagi.s
March 5, 2012 at 5:49 pm #134297
Vsig can communicate with the DSP4000 using MIDI.
I don't know much about Vsig-X since it is not an Eventide product. My understanding is that it requires a serial port – no MIDI.
March 5, 2012 at 7:21 pm #134298
Hi
OK thanks,i will continue now with the manuals etc….
Goodbye for now And big thanks for the Support….
Sagi.s
