Home › Forums › Products › Vsig and Preset Development › Vsig on a Microsoft Surface?
March 1, 2015 at 10:30 pm #112387
Pardon the possibly naive question, coming from someone with Mac only background.
Does anyone know what has to be done to make a Surface work with Vsig?
It even possible?
Thanks
Michael
March 2, 2015 at 12:44 am #127598
No reason why it shouldn't work. I'll give it a try.
March 2, 2015 at 2:21 am #138437
Thanks.
Also any suggestion for a recommended midi interface, or whatever the best way to connect to the H8000, would be appreciated.
Michael
March 2, 2015 at 4:22 pm #138438
Usually a USB to serial interface. When I get it going (maybe later this week), I'll tell you what I use.
March 3, 2015 at 3:50 pm #127601
hi,
i am running Vsig via Virtual Box ( WinXP )under OSX 10.10.2. and a Serial-USB Adapter from Discounter.
Works Fine !
March 4, 2015 at 5:51 pm #138451
I ran Vsig happily on my Surface Pro 2, using a no-name USB Serial interface to connect to the H8000. You will need a mouse, as it does not support the touch screen.
Note that it will NOT run on a Surface or Surface 2.
March 4, 2015 at 10:12 pm #138453
Nick
Thanks very much.
I'll probably get one.
Excuse the zero knowledge of the PC world, but by "no-name USB Serial Interface", are you referring to a midi interface, and is this the only connection I need to use Vsig with the H8000fw?
Much Appreciated
Michael
March 4, 2015 at 10:16 pm #138454
Thanks
The Virtual Box looks intriguing, but potentially gnarly, as if one thing goes wrong I'd have no way to troubleshoot, and might screw up a Mac in the process.
Does one have to buy WinXP, which I've seen on Ebay? Any particular version/flavor?
thanks
MIchael
March 4, 2015 at 11:09 pm #138455
michaelbrook:
You can use a MIDI interface, but people more commonly use a serial interface or COM port (9 pin). These are semi-obsolete these days, but there are many cheap USB-serial adaptors available. There are a number on Amazon for $10-15 – if you pick one that uses "FTDI" it should work (but don't get the $2.50 one !).
March 5, 2015 at 10:34 am #138460
michaelbrook:
You get it 😉 That is for shure .
Quote:Does one have to buy WinXP, which I've seen on Ebay? Any particular version/flavor?You can also work with Win 7 or 8 … there is a list out there.
I use the Usb-Serial Adapter from " Hama " .
You can also use the Midi Pin.
But in my case i can use both. The Visg Data going via VB Serial to the H8 while Logic sends Midi Data ( CC ) to H8 to the Mid socket . Simultaneously.
Good Luck
