Home › Forums › Products › Vsig and Preset Development › Vsig orville / H8000fw
April 21, 2011 at 10:26 am #107819
I have an installation of Vsig 2.4.9 on the laptop that I have used previously with my Orville. Can I use Orville and H8000fw with the same Vsig-application on the same computer?I
Is there a place to see which new modules have been added in H8000fw compared to Orville (relevant to programming presets)?
Thanks
April 21, 2011 at 7:29 pm #121986
razo:
You can, but you should be sure to use the appropriate modules database. Either download it before use, or use Preference/User Setup to select the appropriate one.razo:
Orville is now too old to get an exact comparison. Load the appropriate modules database (as above) and see what is available.
April 22, 2011 at 11:53 am #121987
You can also open both databases with a textfile editor and compare.
June 29, 2011 at 2:56 pm #133562
What about having two installations of Vsig in different folders: one that has H8000fw database and the other having Orville database – Possible?
If yes, also to have the two Vsig's running at the same time – Possible?
Will all .sigfiles developed for Orville work on an H8000fw?
June 29, 2011 at 8:00 pm #133564
razo:
Should be.
razo:
Should be, but untested, and essentially unsupported.
razo:
There may be some module differences that will cause trouble, but I'd guess that 95% will be OK. Again, because Orville is now so old, it's hard to be more precise.
