Vsig under VirtualBox with an imac27 and Lion ?
Home Forums Products Vsig and Preset Development Vsig under VirtualBox with an imac27 and Lion ?
Viewing 4 reply threads
    • #108629
      MFPhouse
        Hi Folks,
        has anybody this successful  running ?
        Vsig + VirtualBox ( WinXP or7 ? ) with an imac27 and Lion ?
        Thanks
      • #123343
        I haven't used this config but I have successfully run Vsig under Parallels with the Win8 preview on a Mac Mini server running Lion 10.7.3. If that worked ok I guess there's a good chance your config will work too.
      • #123352
        MFPhouse
          ok, i will try it. My XP version runs only on the Laptop . So anyway i have to buy i new one.
          Can you run the Vsig + W8 under Parallel Fullscreen  ?
          In my case 2560 x 1440 . ?
        • #123374
          MFPhouse
            Yeppi ! I get it !
            Windows XP under VirtualBox on a iMac i7 27.
            Also the cheap USB-Serial Adapter from Supermarket works !
            Last step ( Problem ) is the result ion of the Display . i want the 2560 x 1440
            Don´t know why it works only with 1600 x XXX.
            VirtualBox can work in Fullscreen Modus.
            XP said is Limited to 1600 x  ( don´t know why ) , but it didn´t capture the Fullscreen Modus in VirtualBox
            Visg has no limit ..or ?
            Thanks
          • #134464
            Great news you got it working then!
            Sadly, I don't have any useful info re your resolution problems.
