Italo,
I rewired my studio, including my MIDI chain, but I believe I recreated the same schematic as before, just different layout of my hardware. My H7600 is working normally as far as MIDI as it relates to program changes, which I control from a MIDI pedal board, so same as before here, no problem. However, the VSigfile utility no longer does anything. When I click on MIDI/Get, I see a quick flash on my MIDI PC interface, showing that "some" signal went through the MIDI chain, but I no longer get the file in VSigfile.
What's a simple test that I can do? I suppose I can take the H7600 out of my MIDI loop and connect it directly to my PC MIDI interface with no loop, but it's not a viable solution long-term. Any ideas of other tests I can run?
