vst is missing on cubase
Home Forums Products Plug-Ins vst is missing on cubase
Viewing 3 reply threads
    • #113451
      stereomatic
      Hi there after installing it on windows 10 running cubase 5 i dont find it anywhere on my vst list inside cubase
      what should i do then ? please help
    • #143368
      tlongabaugh
      HI stereomatic-
      Try going to to Devices->Plug-in Manager and click Plug-in Manager->Rescan all. If that does not work, try the following steps:
      1. Make sure the plug-in is activated in the iLok License Manager.
      2. Eventide Plug-ins are installed to the following locations, please make sure that your DAW is set to look at the applicable custom folder:
            -VST32: c:Program Files (x86)Common FilesSteinbergVST2Eventide
            -VST64: c:Program FilesCommon FilesSteinbergVST2Eventide
      3. If steps 1 and 2 don't solve your issue, close your DAW and delete the following files:
            -VST32: c:Program Files (x86)Common FilesSteinbergVST2Eventide<plugin name>.dll
            -VST64: c:Program FilesCommon FilesSteinbergVST2Eventide<plugin name>.dll
      4. Open your DAW and rescan you plug-ins, and then shut your DAW again.
      5. Reinstall your plug-in, making sure you are using the latest version: https://www.eventideaudio.com/products/plugins
           If you are installing to a custom folder, make absolutely sure you are installing the correct 32 or 64-bit version.
      6. Reopen your DAW, and if necessary, rescan your plug-ins.
      Let me know if that does not solve your issue.
      -Tom
    • #143376
      stereomatic
      Thank you sir it works !!
    • #143381
      tlongabaugh
      Great, enjoy!
