WERKFLEAUX 2 – Instructions to recover old presets
Home › Forums › Products › Plug-Ins › WERKFLEAUX 2 – Instructions to recover old presets
Viewing 5 reply threads
    • #170894
      babacane
        Thanks for the great work done on the plug-ins!
        Could you please give us instructions on how to convert old tide presets into the new nfa ones? I cannot find anything and doing that manually is very difficult.
        Thanks in advance!
        Babacane
        PS: Some months ago I ask you about the VCA type. When using the digital VCA there is always a “realease” even if the release on the LPG is set to 1ms. This is not the case when using the analog vactrol VCA (sound is dying immediately).
      • #170895
        babacane
          Just want to clarify something. I understand old tide presets are functioning well. It is just that adding tags to them changed them to nfa. I was expecting to have only one file at the end of the operation but unfortunately it is not the case. I have the old tide file and the new nfa one with the same name which is confusing, at least for me.
          Thanks again!
          Babacane
        • #171018
          DGillespie
            Ah, that’s a good question. I don’t think there’s currently a way to delete the preset from within the plugin, I think for now you just need to go manually delete the .tide presets after you tag them. I’ll make a bug report about that and maybe we can come up with a better workflow.
             Thanks,
            Dan
          • #171032
            babacane
              Thanks for your reply!
              Did you see also my question regarding Generate’s VCA?
              Ciao
              Bab
            • #171040
              DGillespie
                Yeah, I have to look into it more. I’ve added a bug report.
                Dan
              • #171069
                babacane
