when the specifier display does not work..
Home Forums Products Vsig and Preset Development when the specifier display does not work..
Viewing 3 reply threads
    • #105274
      Hello Italo,
      Probably a very simple question.
      At the moment I am working on some new patches with the latest VSIG version. I am mostly working in the graffic mode. When I double click a module, the specifier display does not open. Other aplications using a double click do work. What am I doing wrong?? I use VSIG on a two monitor computer setup.
       I can work around it using the text mode, but I find the graffic mode more intuitive to work with. Any ideas??
    • #116791
       Hi Harrie
      I assume you refer to Vsig V2.4.9.1.
      I have no problems at all like the ones you describe; working w/2 monitors here too.
      Maybe the module specifier opens somewhere in your displays setup, as a very small window that needs resizing (and maybe relocating on a desired monitor)?
      In any case close Vsig and erase the VSIGFILE.ini file in the Windows directory. This should fix everything.
      Let me know.
    • #116792
      Thank you for your fast responce. I'll try that.
    • #127847
      Deleting the vsigfile.ini did the trick. Thanks again…. Back to building new patches….
