Where are my Pendulate presets?
Home › Forums › Products › Plug-Ins › Where are my Pendulate presets?
Viewing 5 reply threads
    • #116077
      I Just downloaded Pendulate and installed it. It launches in my DAW but there are no plug-ins and no manual either..
      Yes, I looked in my Documents/Newfangled Audio/Pendulate/Presets folder but that is empty. Problems with the installer?
    • #155714
      I figured it out. Here’s the solution if this happens to you.
      First – I don;t log into Windows with the administrator login, I use a secondary ID and password.
      When I down;load Pendulate, Windows promps me for the Admin password and I enter it.
      Pendulate loads into the directory that I specify and puts the documentation and presents into the C:Documents/Newfangled Audio/Penduilate folder as it is supposed to, but it puts it into the Admin’s Documents folder, not the current secondary users documents folder.
      I had to copy it from the Admin’s folder to my secondary users folder and then it works.
    • #155754
      vaikl
        I have nearly the same issue with my new demo of Generate on a MacMini with Mojave 10.14.6. No presets and no manual in the plugin. There’s a new ..<User>/Music/Newfangled Audio/Generate/Presets folder, but it’s empty. My installer is version 1.0.3.
      • #155755
        DGillespie
          Is it possible you installed it with the "Documentation: Factory presets and user guides" option unchecked?  Can you try installing again and make sure that that is checked?
          Thanks,
          Dan
        • #155756
          vaikl
            Aaah, I thought I had only unchecked the AAX plugin but maybe my mouse is on Corona;-))
             Thanks, now it’s working.wink
          • #155757
            DGillespie
              Lol, great!
            • #155715
              DGillespie
                Sorry, I just saw this now. We’ve had three people with this problem, but it’s not everyone with a second Windows account. I double checked the installer settings and they’re all correct, so it must be a problem with the installer software itself. Sorry for the hassle, I’m glad you were able to solve the problem.
