which footswitch for space in combination with tap tempo wahzoo
Home › Forums › Products › Stompboxes › which footswitch for space in combination with tap tempo wahzoo
    • #111333
      kaveman
        I am wondering what footswitches I need for my SPACE for the next setup:
        I want to sync the tempos's of the SPACE and my WAHZOO (wahwah pedal form VOODOO LAB). WAHZOO has also an input for tap tempo so i look for a pedal with one switch for controlling the tempo's of both effects.
        At the same time I want a pedal which I can use for controlling the presets of SPACE.
        So perhaps there is one pedal which supports both functionalities? Other wise which two pedals do I need for both needs at the same time?
      • #125269
        Imerkat
          contact loop-master. You'll need custom order for this
        • #125280
          kaveman
            okay, thanks for the tip.
