Why can’t you delete the last module in an FX chain?
Home Forums Products Rackmount Why can’t you delete the last module in an FX chain?
    • #116589
      moschops
        I can delete modules with a right click no problem until you get to the last module left in an FX chain, then the delete option disappears?
      • #158289
          This is just how the UI is configured; there will always be at least one FX chain and each FX chain will always have at least one algorithm.
          If you'd like a blank slate, you can load the FX chain "1601 TEMPLATE – DEFAULT." You could also simply replace the last algorithm in the FX chain with a "Thru" algorithm, or any algorithm of your choice.
