Why Do My Presets Go Blank?!?!?!
Home Forums Products Stompboxes Why Do My Presets Go Blank?!?!?!
Viewing 10 reply threads
    • #115567
      apalazzolo
         I use the Windows control software and this has been happening occasionally for a long time. I couldn’t quite identify a trigger/cause until recently.   Lately, I’ve been putting the final touches on some preset lists by renaming many of the presets in the list(s) and this problem has ocurred frequently.
        It seems that a preset will reset to blank (all 10 control knobs set to zero) almost every time I rename multiple preset names in a row without making any other changes to these presets.  This seems to happen whether I rename a preset from the preset-list screen or rename and save the preset within the individual preset screen itself.   The preset name does change and is remembered, but I often find that the settings for the preset(s) are all forgotten when I return to the renamed preset(s).
        What’s going on here? Does the rename function of the windows control app have some bugs?  Or am I doing something wrong?
      • #152944
        bohan
          apalazzolo wrote:
          What's going on here? Does the rename function of the windows control app have some bugs?  Or am I doing something wrong?
          Would you be able to take a short demo video? So I can follow that to reproduce this issue. Thank you.
        • #152959
          apalazzolo
            I just update many of the names in my master preset list.  To do that without losing preset data left and right,  I had to access my saved user presets by first selecting each algorithm and then the saved presets.  I was able to reliably rename the user presets that way.  Then I had to use the drag and drop feature to update my preset list(s).
            So renaming user presets accessed via the individual algorithms worked fine but renaming user presets via preset lists was fraught with uncertainty and peril.
            Is it possible that I need to uninstall the control app and reinstall it fresh?  Thanks for your consideration.
          • #156915
            bohan
              Thanks for your detailed description. Now I can reproduce this problem. We'll look into it.
            • #156980
              Hermetech
                Did this ever get sorted? It was happening to me a lot last year, and made me give up on the H9. I had created 52 preset starting patches (one for each algorithm) in a list, and after renaming many of them, they were all reset to zero values. I lost days of work and love for my H9. Been too scared to use the H9 Control app on my PC ever since…
              • #156982
                bohan
                  We'll look into this. Before we fix it, please rename your presets in the preset edit page for now, as apalazzolo said above.
                • #156984
                  Hermetech
                    Thanks, I’ll do some more testing here too.
                  • #157324
                    Hermetech
                      Seems to have fixed it here too with a quick test!
                      But I have also had the infuriating patch name not updating after saving thing too, would love to see that fixed as well.
                    • #157327
                      bohan
                        Hi apalazzolo & Hermetech,
                        Please try this version and let me know if it's working for you. Now the preset should be saved if you rename a preset and click the "Save" button in the preset edit view of the Preset List page. https://share.eventide.com/wl/?id=ZLfLPQ38gBmNZpUU6FG61lcOA0fJ5h7P
                      • #157337
                        bohan
                          You're welcome. Let me know if you notice more issues.
                        • #157549
                          apalazzolo
                            Thanks.
                            If there is going to be a general firmware/control-app update please consider adding ribbon controller capability to the output fader (like in the new stompboxes and plugins) to that too.  I know you’ve heard it before, but just had to ask once more since this could be the last update for the H9.
                            The ribbon controller and hotswitch are unbelievably effective/useful for playing live.   Almost all of my presets make use of them and output control is hugely important for playing live.
                            I know a prior update added expression pedal control as “PARAMETER OPTIONS” but it just doesn’t work well.  It prevents use of the ribbon controller when engaged (a big sacrifice), it can’t be set for subtle changes, and it is glitchy in practice.   For these reasons, the prior fix is just not good enough to be in an Eventide product.  It’s not good enough for the H9.
                          • #152951
                            apalazzolo
                              Thanks for asking.  Unfortunately, I can’t make videos.  I can also offer that I’m using Window 8 and Windows 10 on different computers and the problem happens on both.  I was careful in describing the problem above so I think you should be able to replicate the issue(s).  Perhaps it will also help to say that the preset lists are all made from usrer presets that have been copied to user preset lists.  I select one preset and rename it, then repeat that for the next, then the next, and then the next.  If I then open the newly renamed presets, almost always, the first renamed preset is still in tact but all of the subsequent presets are reset to blank.   I hope that helps.  Thanks for considering this issue.  It’s really frustrating.
                            • #156874
                              apalazzolo
                                Again, I’m sorry I can’t post a video but I have done significant testing to identify the heart of the problem.  It lies in the “rename preset” feature available from the “more” menu WHILE VIEWING THE PRESET LIST SCREEN  (… the “rename preset” feature available when viewing an individual preset is NOT problematic; it works properly).   Almost any time I try to use the preset-list-rename feature my preset immediately goes blank (well, you have to open the individual preset page to see it).
                                I’ve tested this under many circumstances 1. import a preset and rename; 2. modify a preset saved to user presets and rename; 3. modify a preset not saved to use presets and rename, 4. with a fresh reboot of the control app; 5. with a fresh reboot of my computers; 6. with Windows 7 and 10 computers; etc …    It is consistent and not hard to replicate.
                                I now avoid the aforementioned feature/problem like the plague and “save to user presets” often and “rename” from the individual preset screen.
                                Please consider whether there is a bug in the control software.  Thanks.
                              • #157309
                                bohan
                                  Hi Hermetech, can you please try this version and let me know if it fixes this problem? Thank you.
                                • #157310
                                  bohan
                                    apalazzolo wrote:
                                    I now avoid the aforementioned feature/problem like the plague and "save to user presets" often and "rename" from the individual preset screen.
                                    Hi apalazzolo, can you please try this version and let me know if it fixes this problem? Thank you.
                                  • #157315
                                    apalazzolo
                                      Nice work!  With limited testing, this seems to have solved the problem completely.
                                      On to the next and similar problem (one that I have mentioned in a recent thread I started just for this other problem):
                                      With Windows 8 and the rename preset function WITHIN THE INDIVIDUAL PRESET SCREEN, preset changes (modifications to a preset) are not remembered if one also changes the preset name (and saves the preset) and then accesses another algorithm.  He is one scenario:
                                      Create new preset list
                                      Drag & drop any preset into slot 1 … select save and back
                                      Select the preset to enter the individual preset screen
                                      Modify preset knob settings … select rename preset … change name and save … (even save again if you wish … doesn’t matter) and select back
                                      Now you are at the new preset list screen again
                                      Select the algorithm tab at bottom of screen and select any algorithm
                                      Now you are viewing a preset in the individual preset screen …
                                      Select back and you are at the algorithms screen again
                                      Select the preset list tab at bottom and select the newly created preset list …
                                      NOTICE THE NAME CHANGE FOR THE ONE AND ONLY PRESET WAS NOT REMEMBERED …
                                      Select the one and only preset shown there … now you are in the individual preset screen
                                      NOTICE THAT THE CHANGES MADE TO THAT PRESET WERE NOT REMEMBERED EITHER … WHAT IS THERE IS THE PRESET THAT WAS DRAGGED & DROPPED THERE (BEFORE MODIFICATION)
                                      The only way to avoid this failure to remember preset changes (after changing the name in the individual preset screen) is to copy the changed preset to user presets and then to manually place the new user preset back into the preset list
                                      This can’t be normal/intended
                                      Thanks for making great products and please consider solving this other problem as well!
                                    • #157328
                                      apalazzolo
                                        Please try this version and let me know if it’s working for you. Now the preset should be saved if you rename a preset and click the “Save” button in the preset edit view of the Preset List page. https://share.eventide.com/wl/?id=ZLfLPQ38gBmNZpUU6FG61lcOA0fJ5h7P
                                        This works and it’s even better than you said.  I can change the knob setting and rename a preset WITHOUT SELECTING SAVE AGAIN and the settings and new name are both remembered.
                                        Thank you so much!
                                      • #157329
                                        bohan
                                          apalazzolo wrote:
                                          This works and it's even better than you said.  I can change the knob setting and rename a preset WITHOUT SELECTING SAVE AGAIN and the settings and new name are both remembered.
                                          Thank you so much!
                                          You're welcome. You should make sure you click the "Save" button. For example, if you make changes and then click the "Algorithms" tab, you may lose your changes.
                                        • #157333
                                          apalazzolo
                                            bohan wrote:
                                            Thank you so much!
                                            You’re welcome. You should make sure you click the “Save” button. For example, if you make changes and then click the “Algorithms” tab, you may lose your changes.
                                            I’ll watch out for that but I did specifically test for that concern before posting my comment and the changes did “stick”.
                                            Once again, thanks for addressing these problems.
                                          • #157545
                                            apalazzolo
                                              bohan wrote:
                                              You’re welcome. Let me know if you notice more issues.
                                              No new issues at the moment, but my friend is running H9 Control on his Mac.  So I was wondering whether he might need these new solutions or whether these problems never existed in the Mac version of Control.  Any thoughts on that?
                                            • #157546
                                              bohan
                                                We'll release an update for the Mac version soon.
