Why is CRUSHSTATION not showing up?
Home Forums Products Plug-Ins Why is CRUSHSTATION not showing up?
    • #163041
      Dee Fuze
      Just got Anthology XII and everything is showing up in my DAW, except Crushstation. I even tried to download it separately thinking that would do the trick, but it didn’t help. Has anyone else had this issue? Cheers
    • #163043
      Please let me know what OS version and DAW you are using and I can provide some troubleshooting steps to try.
      • #163333
        Dee Fuze
        Sorry for the late reply. I was actually installing the VST3 version of the plugins only, but when I tried the VST2 versions everything worked out smoothly. Someone from Eventide also emailed me with some download/installation advice which will come in handy in the future if I run into similar problems. Thank you for the amazing customer service and incredible products. You guys rock.
      • #163487
        Glad to hear you got this sorted!
    • #168543
      lucifer666111
      I just downloaded crush and it is not showing up in reaper
      • #168547
        Please check if the iLok License Manager is up to date, and make sure your plug-in license is activated.
        After that, try rescanning your plug-ins in Reaper’s preferences.
        If you are still having issues, please provide what OS version you are using.
