Home › Forums › Products › Stompboxes › Will a Boss FV500H exp.pdl work with Eventide stompboxes?
April 1, 2012 at 9:31 pm #108581
wilkinsi
ParticipantI know it will work with my Boss GT-10, but am hoping I can control both that and my Space pedal at the same time.
April 3, 2012 at 8:26 pm #123284
wilkinsi
ParticipantBonus question: Assuming the Boss FV500H is compatible, I want to send commands to three stompboxes simultaneously (e.g.: control pitch on the Pitchfactor, control modulation level on Space, control phaser depth on GT-10). Will splitter boxes cause problems even though they are designed to work with stereo cables?
April 9, 2012 at 4:30 pm #123296
badmelonfarmer
ParticipantNot sure about the H version, but I used the L version fine.
I did use a splitter box when I had three factors… It technically worked… But was not very practical to be honest as it controlled too much that just seemed to make things a mess… I suppose I could have spent more time switching off the factors I did not want to control…. But it go kinda complicated.
Another way to do it is control the first factor with a single lead then control the others with MIDI.
For me, in the end I opted for a mission expression pedal that has 2 channels, you change channels with a toe press… Down side is you can only control 2 units and only one at a time… Unless you use the midi option.
April 10, 2012 at 3:59 pm #134399
wilkinsi
ParticipantThe Space's spec sheet says the exp pedal socket requires a mono 1/4 jack, not a stereo like my Boss unit. I was under the impression a stereo cable would be seperate send and return/toe and heel, no?
As for the FV500, the L means low impedance, the H meaning high impedance, so I'd be able to use the H version as a volume pedal if required at some stage. Both versions only have one EXP jack, hence the need for a splitter for controlling parameters on both the Boss GT-10 and the Eventide Space at the same time.
April 10, 2012 at 4:13 pm #134401
badmelonfarmer
ParticipantUnderstood… Re HIgh and Low impedance … Although in all honesty I have used the L version cot volume too without the drama I expected.
The splitter box I had made was all TRS … Let me go and check again as it was years ago that I was using it with my TimeFactor and ModFactor then the PitchFactor… But I changed to Mission Just after the PitchFactor came out
Let me go and check to see if it works with Space as I would probably have only used the mission with Space…. But it is still a TRS.
April 10, 2012 at 4:23 pm #134402
badmelonfarmer
ParticipantJust checked, buth TRS and Mono worked fine, TRS seemed to work out of the box as I would expect…. Heel = 0 Toe = 90 (need to calibrate I guess)
Interestingly Mono worked the other way and I had to play with the knob on the side to get it to go from heel = 100 to Toe = 0
Either way it works, but would need a little calibration work.
Tried it on a couple of stock presets ModEchoVerb and Blackhole.
I double checked and I do have the L version.
Cheers
Martin
April 10, 2012 at 6:16 pm #134403
wilkinsi
ParticipantSo stereo it is then. Thanks.
April 10, 2012 at 7:49 pm #134404
badmelonfarmer
ParticipantNo worries, happy to help.
Sorry I could not be speciffic with the H version.
April 17, 2012 at 4:31 pm #134422
wilkinsi
ParticipantI connected the stereo jack to the Space. The SPC manual says move the exp pedal to heel, the EDITED LED flashes (briefly I might add), then move the knob to be controlled. By the time I move the FV500's pedal position, its already controlling two parameters I don't want. The EDITED LED also stops flashing/goes solid very quickly. Do I need to clear the exp assigns somehow? Is there a more intuitive way to assign the pedal to knob functions? All I want to do is control the Pitch A and B, so that when A moves to a positive amount, B moves to a negative. On another preset, I want the FV500 to adjust between Flange 100 and Sweptverb 100.
April 18, 2012 at 12:49 am #134423
wilkinsi
ParticipantForget my 2nd example. I fixed that with the Hotswitch.
April 28, 2012 at 12:41 am #134460
wilkinsi
ParticipantI feel there must be a more intuitive way to clear and assign new EXP PDL settings, perhaps using FactorLib by setting (alpha-)numeric values for toe and heel position? Educate me please.
