Home › Forums › Products › Stompboxes › Will a CV pedal work with Pitchfactor?
October 7, 2019 at 12:32 am #115547KentuckyThrashMember
As I’ve been through 5 passive expression pedals now trying to get a smooth throw with the Pitchfactor, I’d like to ask: Will a CV expression pedal work? I figure if the pedal is controlling the voltage it will be smoother throughout.
October 7, 2019 at 2:53 pm #152869KentuckyThrash wrote:
As I've been through 5 passive expression pedals now trying to get a smooth throw with the Pitchfactor, I'd like to ask: Will a CV expression pedal work? I figure if the pedal is controlling the voltage it will be smoother throughout.
Depends on your exact problem. If:
1) The control range is bad, i.e. too tight at eithr the top or bottom, a CV pedal will help.
2) The pedal is not reading the pedal quickly enough, so that changes are jerky, a CV pedal will not help.
October 10, 2019 at 12:20 am #152898
H9 is the same as PF. The jack is designed for expression pedals rather than for CV, so you're kinda using something that it is not designed to do, but might be worth trying.
October 7, 2019 at 3:58 pm #152873KentuckyThrashMembernickrose wrote:KentuckyThrash wrote:
Great. Scenario 1 is the case. Can you provide any CV specs / recommendations for the pitchfactor?
The PF wants an input between 0 and 3.3V.
It will not be damaged by values outside this range (within reason!), but the full control range will only be between 0 and 3.3.
October 9, 2019 at 4:12 pm #152887KentuckyThrashMembernickrose wrote:KentuckyThrash wrote:
Hmm. So a +5V expression pedal’s last 20% of sweep or so wouldn’t do anything? I don’t see any pedals out there with specifically a 0 to +3.3v range. Would the Mission SP-H9 work with the Pitchfactor? Is the H9’s expression input the same as the Pitchfactor?
