Will my settings change when upgrading from 2.00b7 to 2.02b4 ??
Home Forums Products Stompboxes Will my settings change when upgrading from 2.00b7 to 2.02b4 ??
    • #105637
      Andy S
      Hello, when i upgraded from version one to beta 2.00 my saved patches sounded quite different and I had to go in and adjust the mix and filter on just about every saved setting. Took quite a bit of time.
      When I upgrade from 2.00 to 2.02 can I assume this wont be the case since there have no changes in the mix and filter parameters……..? Or will i have to re-do everything again ?
      Could someone chime in and let me know………..I was thinking if upgrading but I have a bunch of gigs this weekend…….so maybe I'll wait if it will alter my saves ( that I have dialed in perfectly right now ) …….
    • #117492
      achaput
      The changes in the newest TimeFactor Beta release are less sound-altering than in the previous Beta release. However it is still recommended that you back up your sounds before updating (Use the PRESETS choice when dumping sounds) and that you do not update right before a gig.
