Wimpy when bypass is on
Home Forums Products Rackmount Wimpy when bypass is on
    • #107360
      mikemerrill
      I use an eclipse with my T sax for additional voicings live. when I hit bypass the sound is great but less of it. It may be ideal if there were some way to have the volumn increased when bypass is used.
      I have a a single space Rolls mixer I used with the eclipse. run the monitor out to the eclipse then both outs back to the mixer.
    • #120938
      By definition, BYPASS bypasses all machine functionality, so it would not make sense to have gain in bypass.
      Better to find what your problem is. You don't say which bypass mode you are using. Of course.
      If you are using relay bypass try changing to dsp bypass.
      If you are using dsp bypass and still get a gain change in bypass presumably this means that the effects are adding gain – you can try changing the effect parameters or adjusting the wet/dry settings.
