Wiring of external switches for H90 ?
Home Forums Products Stompboxes Wiring of external switches for H90 ?
Viewing 3 reply threads
    • #169406
      dhub
        Can anyone tell me how the external switch wiring on a TRS connector ( tip, ring, sleeve) translates to switch number 1,2,and 3 ?
        Thanks in advance
      • #169407
        joecozzi
          Tip = 1, Ring = 2, T+R = 3. Sleeve is usually the ground for all three buttons.
        • #169408
          dhub
            Are there any diodes required?
            Thanks again
          • #169409
            joecozzi
              Yes, two 1N4148 that should be wired with the stripes pointing toward the third switch. I’ve attached a schematic.
