November 13, 2018 at 1:41 pm #150588ArguZ wrote:
Could I ask for the wiring specs for the In and Outs please.
The DB25 analog IO follows the Tascam pinouts, standardized in AES59.
This Wikipedia page has the details: https://en.wikipedia.org/wiki/D-subminiature_%28professional_audio%29
Please let us know if you need any more info!
November 13, 2018 at 1:49 pm #150589
ArguZ
ParticipantAh, thank you 🙂
So here a PDF with the full wiring diagram where GCH = SRT , correct ?
http://whirlwindusa.com/media/uploads/downloads/manuals/wwdb25tascpin.pdf
S=G=Ground
R=C=Cold
T=H=Hot
November 13, 2018 at 1:54 pm #150590ArguZ wrote:
Ah, thank you 🙂
S=G=Ground
R=C=Cold
T=H=Hot
Yes, thank you! This diagram is much better than the table on the wikipedia page.
November 13, 2018 at 2:07 pm #150591
ArguZ
ParticipantOk, cool…
Do you know if pin 13 is common ground ?
If so i would use that as the return line on the NMJ6HC-S
So the signal that is on all three pins when nothing is inserted.
November 13, 2018 at 2:34 pm #150592
ArguZ
ParticipantAll right, PCB design done…
two of those in a box should make a nice patchbay for my 4 stereo synth signals.
November 13, 2018 at 3:59 pm #115058
ArguZ
ParticipantHello,
I am gearing up for my H9000 to come and I decided to build my own breakout box for the DB25 IOs
I will make a custom PCB that hosts 4 Neutric female TSR connectors and a box that hosts two of them.
So an 8 TSR jack patch bay.
kind regards
Sascha
