January 17, 2014 at 2:34 pm #111322wilkinsiParticipant
I don't have enough space behind my gear to use a T-bar. Is it possible to use both W/C IN and OUT so the Eclipse is slaved to W/C but still carries that signal onto the next device that requires W/C?
January 17, 2014 at 4:25 pm #125254
Don't see why not. There might be a minimal increase in jitter, which would give a tiny increase in noise and distortion, but this is unlikely to be noticeable.
February 27, 2014 at 7:44 pm #125475wilkinsiParticipant
Is the w/c input of the Eclipse terminated? I now need to add another w/c device (ADDA converter).
February 27, 2014 at 8:44 pm #136232
See p.55 or the Eclipse UM.
March 1, 2014 at 1:08 am #136238wilkinsiParticipant
Of course, I forgot. Contemplating a word clock generator. By the time I'm finished. I'll have 6 sources with word clock inputs, 6 T-bars and 6 terminators.
March 2, 2014 at 4:36 pm #136240
Only one terminator per source please ..
March 12, 2014 at 12:22 am #136262wilkinsiParticipant
Does it matter which shorting link I use? There are different ones, e.g.: 1 looks like a plastic clip with a semi circle cut out, another looks like a screw bent into a straight C.
March 12, 2014 at 3:49 pm #136266
Not sure what you are using it for. They will presumably either work or not.
March 13, 2014 at 12:24 am #136268wilkinsiParticipant
No problem, probably easier to just fit a t-bar and terminator.
