Wordclock Input BNC connector replacement?
Home Forums Products Rackmount Wordclock Input BNC connector replacement?
    • #110987
      wilkinsi
      The metal part to which I would connect a BNC cable is damaged. Can I easily replace this myself?
    • #124592
      Depends on how handy you are. The metal part can't be changed by itself, because it is part of a double socket. You would have to take the unit apart and and solder the part from the motherboard and replace it. Probably a job for a dealer, but if you want to try it yourself, support@eventide.com should be able to supply the part as you probably cannot get it locally..
    • #124593
      wilkinsi
      I went at it with a pair of thin nose pliers instead. My T-adapter now fits and I can lock to wordclock. There isn't exactly massive space to get at it with a spanner.
