Write/Erase Loop H9 will not function
Home Forums Products Stompboxes Write/Erase Loop H9 will not function
Viewing 3 reply threads
    • #114405
      mkatilius
      I was having bluetooth pairing issues with my H9/Control on my mac (im running Sierra) so i tried to re-install my H9’s firmware through the H9 control software via midi connection. I forgot I updated this way once before and it bricked my H9 in this way where it displays Update then Write…/Erase… in an endless loop. Well, it happened again.
      The first time this happened i read the forums and saw that I can reinstall the update with the old direct updater and that time it worked.
      I tried this again and the direct updater software will not even recognize myH9 at all and yes, I am starting it in Update mode by holding the hot knob at power up, but it immediately goes into the write/erase loop after Update displays for a couple seconds.
      Please send me a software patch I can run to get use of this thing because as of now it is bricked again and I cannot get it reset to factory or anything.
      I have sent this same message in via a support ticket request.
    • #147409
      I'm puzzled that it does this, because entering update mode should clear the failed update. Sorry.
      There's nothing we can send you – support@eventide.com
    • #152680
      leducd71
      Hello
      how to erase the last loop without erasing previous loops?
      Does there exist an undo function ?
      Thanks
    • #156194
      guestantoine
      Same problem here.
      Is there any way to solve that issue?
      Thx
    • #152683
      bohan
      leducd71 wrote:
      Hello how to erase the last loop without erasing previous loops? Does there exist an undo function?
      Unfortunately, there is not an undo function for the Looper algorithm.
    • #156195
      guestantoine wrote:
      Same problem here.
      Hi – unfortunately, this thread describes two different problems, one with the updater, the other with the looper.
      To which do you refer ?
    • #156196
      guestantoine
      nickrose wrote:
      guestantoine wrote:
      Same problem here.
      I was stuck with the updater problem but problem solved now. I didn’t wait enough time before writing my previous message. I relaunched the H9 and let run the erase and write message for a bit. After 5minutes the update was done. It’s working perfectly now. My bad.
      Thx
